Rattling noise coming from underneath the front of the car
120,000 MILES • 4 CYL • FWD • MANUAL
RLT623
My 2006 saturn ion in the past year has had to have replaced a brand new clutch, a new clutch pedal, a transmission replacement, and a couple of other things do to a bad mechanic. It has needed new struts for
quite some time I believe but now it is making this rattling noise when I switch gears and accelerate . It started out in only first gear and has begun to progress quickly into second, third, fourth, and now is happening in fifth gear. Except that now it's getting louder and you can hear it when your on the highway now constantly. I am not sure what it is. Some one told me they thought it was my motor bearings, or something of that sort and that eventually it's just going to fly apart inside my motor. I am wondering if anyone could help me out with information about my problem. Theres been countless things with this car that really should be recalled by the company if they haven't already and everyone of them has gone wrong with my car.
Jan 29, 2014 at 2:34 AM
CARADIODOC
  • 34,413 POSTS
Recalls are not issued just because you're having a lot of trouble. They are only initiated when a large number of a certain model has a high likelihood of developing the same safety or emissions-related problem, or for some manufacturers, a customer satisfaction issue. Service bulletins are also issued when a lot of cars may develop an elusive problem that initially defies a quick diagnosis. Those are just informational so mechanics can fix a car faster, but those are not recalls and no attempt is made to contact the owners of those models.
It isn't likely the engine bearings are worn out yet at the mileage you listed, unless the car has not had proper oil changes and other maintenance. When a knocking does occur that's caused by a worn bearing, it won't last very long like that. If you're real lucky, you might get a few hundred miles before the damage escalates very quickly and a part breaks and the engine locks up. There are other things that can cause a knocking noise. Some of them are relatively minor but can turn serious if they're ignored. A loose or broken vibration damper is one fairly common cause that comes to mind. Also, engines that use timing chains with tensioners can develop looseness and rattle against a cover. You didn't say which engine you have, but all of them for your model use a chain. You should be able to hear that with the hood open and you're standing next to the running engine. A mechanic can differentiate that noise from a connecting rod bearing knock. A loose timing chain can last for a pretty long time but it will also cause slightly reduced power and fuel mileage.
There is a tool you might be able to borrow or rent from an auto parts store that borrows them called the "Chassis Ear". It is a set of six microphones, a switch box, and headphones. You clip the microphones to suspect points, then drive around while listening with the headphones. You can move the microphones around to zero in on the source of the noise. Be aware that many mechanics have never seen or even heard of this tool. Suspension and alignment mechanics use it to find rattles, squeaks, and other noises.
Jan 29, 2014 at 2:57 AM
RLT623
What I meant when I was talking about recalling the car is that every time I have a problem and I look it up their are thousands of consumers that have the same problem has I have had. I did get a letter last year that advised me of a recall for my vehicle it had something to do with the fuel system and could cause the car to catch fire. My issue just started last week and has progressed rather fast. Just getting louder everyday. I am taking it in to a gm repair shop tomorrow and hopefully it's nothing major
Jan 29, 2014 at 3:43 AM
CARADIODOC
  • 34,413 POSTS
I hope it doesn't turn out to be something expensive. Holler back with some good news once it's fixed.
Jan 29, 2014 at 12:19 PM
