Try this info:Some customers may comment that their vehicle will not start. This comment is referred to as "no crank, no start with complete power."
Additional customer comments may be as follows:
"Â A clicking noise may be noticed when the key is first turned to the START position, but no noise is heard after the initial start attempt.
"Â The "Security" light may flash immediately after trying to start the car along with the message "Service Vehicle" in the Driver Information Center.
"Â The vehicle may not start for at least 10 minutes after the first attempt to start the vehicle. Diagnostic trouble codes (DTCs) B2960 and or B3033 may be set in history in the BCM.
Cause
When the key is rotated from RUN to START there is a voltage signal sent to the BCM that goes through the PASSLOCK resistor in the ignition switch. This voltage signal may have an early ignition switch bounce (when going from RUN to START) that the BCM interprets as a failure in the PASSLOCK system and disables the starting circuit.
Using the chart below, verify that the ignition switch has been replaced at least once using P/N 10392423. After replacement of the ignition switch or replacement and reprogramming of the BCM, perform the 30-Minute Learn Procedure found in Programming Theft Deterrent System Components.
Step
Description
Install scan tool.
Are DTCs B2960 and/or B3033 present in BCM History?
Go to Step 2
Bulletin does not apply.
2
Check NVH (National Vehicle History) (in Canada, GMVIS).
Has ignition switch been previously installed? If yes
Replace the BCM.
If no Replace the ignition switch. See if this works, post back with what you find.
SPONSORED LINKS
Saturday, January 17th, 2009 AT 10:03 AM
