2004 Saturn Ion
LITA9808
  • 2004 SATURN ION
2004 Saturn Ion 4 cyl Front Wheel Drive Manual
when driving I set the cruise control it works for a while then shuts off. It will turn back on after driving for a while. Any ideas what it could be
Wednesday, June 4th, 2008 AT 6:06 AM
MASTERTECHTIM
  • 4,749 POSTS
Check to make sure the brake switch is adjusted properly. If you have a touchy brake light switch it may slightly turn on while driving down the bumpy road thus disabling the cruise.
Wednesday, June 4th, 2008 AT 6:33 AM
LITA9808
What exactly is a brake switch or where would it be located
Wednesday, June 4th, 2008 AT 6:30 PM
MASTERTECHTIM
  • 4,749 POSTS
Its located under dash right above the brake pedal. When you press the pedal you will see the switch moving, there is a plunger that comes out when pedal is pressed.
Wednesday, June 4th, 2008 AT 7:06 PM
