2003 Saturn Ion Two Wheel Drive
I have recently discovered a leak of coolent from my car. I believe it is the hose due to the amount that leaks but my new mechanic (new since I moved from Mass. To Va.) Thinks it might be the radiator. What would be the cost differential between replacing a hose and replacing the radiator bot of which he said would be a couple of hundred?
SPONSORED LINKS
Thursday, June 17th, 2010 AT 7:15 PM
