1995 Saab 900 Dies in Gear
1995 SAAB
AMAHKAJ9
I have a 1995 900 se 2.5 v-6 automatic. When I put it in gear,it kills engine abruptly.I have been told this may be a tcc solenoid problem. I am not sure how to find this part on the car. I would appreciate some help with this problem.Also,if anyone has any other ideas,please let me know.I am open to trying anything. Nobody in my area works on Saab automatics ,so i am lost. Thanks for any help
Oct 9, 2007 at 8:52 AM
MERLIN2021
  • 17,250 POSTS
I am not a Saab guy either, but if the check gearbox light is on, either steady or intermittent, it's not the TCC...Your symtoms seem more like the Gear Position Sensor...If you can get the code read, it will remove all doubt were to look!
https://images.2carpros.com/forum/automotive_pictures/62217_sensor_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_30961_mitchell_2_51.jpg
Oct 9, 2007 at 10:15 AM
Suggested Repair
If the check gearbox light is on, suspect the gear position sensor rather than the TCC solenoid. Have the transmission codes read to confirm where to look.
Conversation Summary
The owner of a 1995 Saab 900 SE 2.5 V6 automatic says the engine dies abruptly when the transmission is put in gear and wonders if the TCC solenoid is at fault. The expert says a steady or intermittent check gearbox light points away from the TCC and toward the gear position sensor, and recommends reading codes to confirm the diagnosis.
