1986 Saab 900S Blows Oil From Exhaust
1986 SAAB
JEREMY1
hi, i own a 86 saab 900s recently my saab began to sputter, stal and blow oil from my exhaust. the car starts and runs fine for about 3 minuits then begings to act up. i was wondering what can cause the oil to be blowing out the tail pipe and why it doesnt happen immeditaly? thanks
Feb 15, 2006 at 2:21 PM
PEPPERMRJ
  • 1,158 POSTS
Doesn't sound good for the home team. First thing that comes to mind is a head gasket failure. A compression check should tell the tale.
The only easy thing that you could hope for is that the oil is overfilled and is being sucked in thru the PCV valve.
Good luck and let us know.
Feb 15, 2006 at 11:35 PM
Suggested Repair
Perform a compression check to look for head gasket failure. Also check whether the oil is overfilled and being drawn in through the PCV valve.
Conversation Summary
The owner of a 1986 Saab 900S reports that the car starts and runs normally for about three minutes, then sputters, stalls, and blows oil from the exhaust. The expert says this may indicate a head gasket failure that a compression check can confirm, or that the oil may be overfilled and drawn in through the PCV valve.
