u've got some kinda fuel ctrl problem..i am 100% sure that a real tech doesn't repair or diagnose car problem by guessing...at least we don't in our shop..they pin point ur problem by understanding how a system work ,listen to ur complaints ,test drive and verify the symptoms ,process of elimination by testing then perform repairs and verfy repair...diagnose problems is whats mechanic all about...hanging parts are the easiest thing ..to pin point and tell u the problem is the mechanic ... so ...to answer ur questions ....yes u can fix ur car urself with enuff equipments ,training and info...95' cars are pretty much out of most owner capabilty for reapiring compare to the 70's...if u can't fix a tv set from the 70's-80's ...pretty much u can't fix a 90's tv or a car........good luck
Feb 21, 2007 at 9:03 PM
