1998 Saab 900 Rubber smell, battery light, lost power steer
JONE_S4757
Smells problem
1998 Saab 900 4 cyl Two Wheel Drive Automatic 157K miles
Last night my car started hard, but it did start and I smelled a faint rubber smell while driving (only two miles to get home from work). Later, I took it out, it started fine and then my battery light went on and I lost my power steering. It seems my heater is working. When I turned it off, there was alot of steam from under the hood. I let it cool off and about an hour later, I restarted it with no problem, lifted the hood and saw my coolant was very low. I refilled it, but the battery light is still onl I have been dealing with a coolant leak for a while (replaced some hose and checked radiator which seems okay). I also had the sepentine belt replaced recently. I should also add that we are experiencing record cold temps in this area. Any ideas?
Feb 27, 2008 at 9:59 PM
MERLIN2021
  • 17,250 POSTS
With the power steering, cooling, and charging system not working, it really sounds like you lost that new serpentine belt! This time I think you need ALL pulleys checked for bad bearings and a new tensioner installed...
Feb 27, 2008 at 10:02 PM
MERLIN2021
  • 17,250 POSTS
Answer to your PK: No it's not labor intensive, unless the a/c compressor, water pump or power steering pulley(s) need attention...
Feb 27, 2008 at 10:50 PM
