1997 Saab 900 how to change the water pump
1997 SAAB 900
DAVTIE
Engine Cooling problem
1997 Saab 900 Two Wheel Drive Manual
hello, just want to ask if its okay for me to change my water pump myself. I am fairly familiar with bit of mechanics, servincing cars, changing break pad and stuff. I have a spare water pump as well. How do i locate the water pump and any advice as to how to change it?
thanks.
Feb 12, 2009 at 8:24 PM
DAVE H
  • 13,384 POSTS
WATER PUMP Removal (900 Series) Drain coolant. Remove drive belt. Remove pulley, water pump retaining bolts, and water pump. Installation (All Models) Clean gasket surfaces. Install new gasket. Install water pump, belt tensioner pulley, and drive belt. Reverse removal procedure to complete installation. Tighten bolts to specification.
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_354.png
Mar 22, 2009 at 12:34 AM
