2001 Saab 9-5 Engine Oil light cam on and car died
128,000 MILES • 4 CYL • FWD • AUTOMATIC
JCDKEL
  • 7 POSTS
took car to shop as car died couple days ago, they gave current codes 1334 combustion detection fault cyld 3+4 out of sum,1312 combustion detection fault cyld 1=2 out of sum.... shap said need to replace DI cassette, but still ok to dirve, may leave me sit at some time.... ran car for 2 days , after 45miles drive home , oil pressure light came on and car died, checked pressure and was OK, tryed to start and wouldnt start, waited awhile and started but rough,oil light out, ran for about 1-2 miles oil light came on, limped home, if I replace DI , will oil issue go away or is this a seperate issue from DI ??
Dec 27, 2009 at 3:38 AM
MNTHNY4
  • 612 POSTS
Did your oil light stay on while limping home ,if yes you may need to drop oil pan & check for sludge plus clean oil pickup screen ,changing DI cassette does not help oli presure light issue ,but will cause more serious electrical wiring problems ,if u continue to drive with it ,when it gets really bad it will start burning the connector & wiring harness ,get oil light problem checked ASAP ,could cost u a engine if u keep driving while light is on,good luck.
Dec 28, 2009 at 12:45 AM
JCDKEL
  • 7 POSTS
looks as if the pan was dropped some time before I bought auto, as can see new gasket sealant around pan, but will drop again to make sure, Oil light was out as limped home, but did come on at times, I pulled over , let car sit and light went out, limped a little more light on ans so on until parked
Dec 28, 2009 at 1:17 AM
MNTHNY4
  • 612 POSTS
ok ,sound like it for sure u have a oil pickup screen blockage problem ,this time try & remove as much debris as u can both from top valve cover area & lower engine block ,i have found that a good brand oven cleaner works great ,much better than grease remover ,good luck .
Dec 28, 2009 at 7:30 AM
JCDKEL
  • 7 POSTS
should I continue to use synthetic Oil or regular? would this help or hurt engine, oil has a little gassy smell to it, If i clean out pick up and other related parts will this continue to be a maintance issue?
Dec 29, 2009 at 2:24 AM
MNTHNY4
  • 612 POSTS
no u should be good after that because i did that to my engine 3 years ago & i am still running strong with lots of mod's to engine , plus i only use full syn oil ever 3000 miles ,it is best to use only full syn oil ,trust me i know ,don't play cheap with your engine , just saying ,good luck.
Dec 29, 2009 at 12:29 PM
