2003 Saab 9-5 oil light
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALPHAWAVE
my oil light is on, there is a large explaination point (!) and it beeps. I checked the oil, it is full.
Feb 20, 2010 at 6:52 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch/sensor.If abnormal could mean oil pump and engine bearing.
Feb 20, 2010 at 9:32 AM
MNTHNY4
  • 612 POSTS
u may have a blocked oil pickup screen ,[sludge ] get engine internals checked ,remove valve cover first [check for sludge build up inside engine ] if found remove oil pan & clean out sludge ,i have found out that a good oven cleaner works great for breaking down sludge ,good luck.
Mar 15, 2010 at 3:37 AM
