2002 SAAB 9-3 repair Question won't start
DGILLES
  • 2002 SAAB 9-3
Electrical problem
2002 Saab 9-3 repair Question 4 cyl Front Wheel Drive Automatic
car acts like it is not firing, owner replaced all fuel system components, I can't seem to find the spark plugs or crank sensor is this car equipped with the ignition cassette
Tuesday, October 27th, 2009 AT 1:23 PM
MNTHNY4
  • 612 POSTS
Yes car has direct ignition cassette located in the middle of valve cover, your crank shaft position sensor is located at the front lower section of engine look where engine & transmission meet behide muffler pipe it will be screwed into block & wire run to the back of eng electrical connector end will be blue in colour. Good luck
Tuesday, October 27th, 2009 AT 7:01 PM
