2001 SAAB 9-3 repair Question car wont start unless I pour g
DIRKOUS
  • 2001 SAAB 9-3
  • 4 CYL
  • FWD
  • 102,000 MILES
My car wont start unless I pour gas in the carb
is the fuel pump or fuel pressure regulator?
Friday, July 4th, 2008 AT 2:42 PM
MNTHNY4
  • 612 POSTS
First things first did you check for blown fuses, if so than check if you have fuel pressure at the fuel injector rail at the top of the eng, just infront and below the engine oil filler neck section, there is a black valve looking cap screwed on to the test port, unscrew and press shreader valve if gas spray out than you have fuel pressure, which inturn says to you that the pump is working, so good luck
Saturday, July 19th, 2008 AT 6:27 PM
