1999 Saab 9-3 repair Question Starting
1999 SAAB 9-3
72,500 MILES • 4 CYL • FWD • AUTOMATIC
JACK606
Over the past two months I have had to have mycar towed three times. Car cranks cranks cranks and finally sputters and coughs to a start. The first time they replaced the crank sensor. The second time thet told me they thought it was bad gas that I should let it run down to almost empty fill it with Mobil and dry gas, repeat this a second time, I actually did this three times. The third time they told me I should get it out for a good run on the highway and keep using dry gas. I did this a couple of times. They have runit on their computers and tell me they get no codes. They have supposedly checked every part, wire fuse etc. Nothing. Still the problem. Onced the car starts it runs like a dream. It has also got a brand new battery, M.A. McGlone e-mail jack606@aol.com
Jan 8, 2009 at 9:40 PM
Duplicate the problem Check the fuel pressure and injection pulses while cranking it over if okay look for spark then get back asap.
Jan 8, 2009 at 9:51 PM
JACK606
SAAB dealership told me the last trip in Xmas week that they did this and everything was fine
Jan 9, 2009 at 10:41 AM
Get the coolant temperature sensor/fuel pump relay if it has one and ignition switch tested.
Jan 10, 2009 at 5:23 AM
