Hi, I was driving to the store last week and I smelled gas. I went home, opened the hood and was checking by the injector and saw a pinhole leak coming out of number one injector. So I went and got a new injector for my truck. (by the way the truck had no issues prior to the replacement of the injector). I replaced the injector and replaced everything the way it came off, started the truck back up and no leaking was seen so I started to go around the block and now it feels like a misfire/bogging out? I was going to replace the plugs and wires anyway so I did. No change.. I went through everything I touch or moved while I was replacing the injector and cannot see anything wrong. Granted I am no mechanic but I cannot figure it out. So I did all the internet stuff I could without throwing parts at it.. Checked out the MAF and cleaned the EGR (little carbon build up but better than the videos I have seen). I cannot afford a mechanic right now and need the truck for work. Any and all ideas, suggestions, and tests I can do would be greatly appreciated. Thanks in advance. Steve
Apr 28, 2018 at 7:19 AM
