[quote:33f2a28c8c="tucdon"]Engine Performance problem
2000 Ford Ranger 6 cyl Two Wheel Drive Automatic 125000 miles
engine misses when idling and driving not bad but noticable .changed egr valve and regulator as well as plugs and wires[/quote:33f2a28c8c]
If engine light is on get codes pulled and post.
Other causes of misfires are...
Low fuel pressure do to Weak Pump...
Low engine compression...
Faulty IAC (Idle Air Control Motor/Valve)
Vacuum Leaks....
Faulty or Leaky Injectors....
Faulty Fuel Pressure Regulator...
Apr 28, 2009 at 10:51 PM
