All replacement thermostats keep sticking closed causing the engine to run hot?
165,000 MILES • 3.4L • V6 • 2WD
FRANK38061
I replaced the coolant system parts that were bad; the water pump, radiator, thermostat, reservoir cap, temperature coolant sensor, and bled the system. However, I drove the car for 1 hour and the thermostat stuck causing the car to run hot. The thermostat keeps getting stuck no matter how many news one I put in there they get stuck and causing it to run hot.
Aug 1, 2023 at 12:05 AM
  • 55,604 POSTS
Yep, this happens when the handbasket blows because it forces exhaust into the system which the thermostat will not react to. To confirm the issue please go over these guides:
https://www.2carpros.com/articles/recognizing-the-symptoms-understanding-a-blown-head-gasket-in-your-vehicle
and
Please go over these guides and get back to us.
Aug 1, 2023 at 6:40 AM
