Running hot when stopped
180,000 MILES • 2WD • AUTOMATIC
AW2018
  • 6 POSTS
For the past six or more months my car has been running hot but only when stopped. We changed the thermostat in it because the diagnostic test said that is what it was. It ran fine for a little bit. Now it i's back to doing the same. I never see any fluids under the car when stopped like its leaking but we are having to add fluids every three to four days. There is also a smell like burning fluids and some days thick (some days nothing) white smoke from the tail pipe. We have had people mention it needs a radiator flush maybe a new water pump or it may be blown head gasket. Any advice is greatly appreciated.
Sep 2, 2018 at 2:44 AM
AL514
  • 5,683 POSTS
Hello, and thanks for using 2CarPros.com. I am sorry to be the bearer of bad news, but it sounds like you have a bad head gasket. Fluids are going into the cylinders and being burned, hence the white smoke.
Sep 2, 2018 at 3:13 AM
AW2018
  • 6 POSTS
Okay, so what all does that consist of getting it fixed? Should we stop driving it until we are able to get it fixed?
Sep 2, 2018 at 3:17 AM
AL514
  • 5,683 POSTS
Yes, you may want to stop driving it, overheating the engine over and over will warp the head itself. So you need to take it to a shop and have them replace the head gasket and while they are there you may want to have them do the timing chain or belt which ever it has, if it has not been done. I see this is a V6 as well, meaning you have two head gaskets to do.
Sep 2, 2018 at 3:35 AM
AW2018
  • 6 POSTS
Thank you! What is an estimate on repairing all this?
Sep 2, 2018 at 3:50 AM
AL514
  • 5,683 POSTS
Unfortunately, it is expensive, some prices range around $1,000.00, but you have two head gaskets to do. So just go get a couple estimates, it will vary shop to shop.
Sep 2, 2018 at 4:26 AM
AW2018
  • 6 POSTS
Thank you for all your help!
Sep 2, 2018 at 4:32 AM
AW2018
  • 6 POSTS
So we got in the shop. It was not blown head gasket but some other gaskets needed to be changed. Got a new water pump because it was leaking. Car was still running hot. Got a new radiator car is still running hot. They are saying they have not seen any thing like this before. Any ideas what else could be causing it to run hot?
Sep 17, 2018 at 11:04 PM
  • 55,594 POSTS
If I may this sounds like a blown head gasket still. A head gasket chemical test is only about 75% accurate. Is the cooling system constantly down and you cant find a leak?
This guide can help as well.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Cheers, Ken
Sep 20, 2018 at 9:31 AM
AW2018
  • 6 POSTS
Thank you! Well, after further searching and looking they found it is a blown head gasket.
Sep 20, 2018 at 9:44 AM
  • 55,594 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Sep 21, 2018 at 3:07 AM
PAINTINGMD
Engine Cooling problem
2005 Chevy Equinox 6 cyl All Wheel Drive Automatic
water pump works doesnot move water through engine
Sep 21, 2018 at 3:08 AM (Merged)
  • 110,248 POSTS
How do you know the pump doesn't work? Is it turning? Have you checked for circulation in the radiator? Have you checked to make sure the thermostat isn't sticking shut?
2CP-ARCHIVES
  • 4,540 POSTS
i put a new thermastat in and it is still running hot.
rad may be clogged or you may have a failed head gasket from constant overheating
