RPMs do not go above 1,000
110,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
CRAIG74
I serviced the car a month ago and put some diesel fuel additive to clean the carbon through the system. I ran the car for about 40 miles it's not smoking at all. I even took a cloth to wipe the tailpipe and the cloth was still clean. My issue is that when I drive at times it will have abit of power then after short distance it just wants to cut out, so i have to keep changing gears just to get me home. I have cleaned the EGR valve and throttle body but no change. please advise. what could be the problem as it is the car i will be using to commute?
Jun 16, 2021 at 2:16 PM
  • 55,732 POSTS
We need to check for codes to see what comes up. here is a guide to help us. It sounds like the throttle pedal position sensor is out:
Jun 18, 2021 at 5:34 AM
CRAIG74
Thank you so much. i will get the throttle pedal and let you know how i get on.
Jun 20, 2021 at 7:49 AM
  • 55,732 POSTS
Jun 21, 2021 at 3:20 AM
