2006 Mazda 5 misfire #1
120,000 MILES • 4 CYL • 2WD • MANUAL
UPI
My car started to run rough, took it to auto store and they hooked it up to scan for codes. They said misfire in #1. I have checked the plugs , the ignition coil and the fuel injector all good. What else could be the problem ? This one is driving me crazy, help will be greatly appreciated.
Sep 18, 2010 at 10:09 PM
  • 75,988 POSTS
P0301 Misfire at no.1 cyl-Check the compression for no.1 cylinder-you did the plug and injector on it and checked out-
Sep 18, 2010 at 10:14 PM
UPI
Thanks for the advice, just did a compression test all were 75 psi exept for the #1 zero psi. Checked the coolant and it looks clean, oil looks clean too.
Sep 19, 2010 at 4:30 AM
