1999 Rover 75 overheating problem
DHUPS.GOSWAMI
Engine Cooling problem
1999 Rover 75 6 cyl Automatic
Overheating ( Temp Gauge will go up to 2/3 after 10mins driving). My friend said somewhere the pipe from radiator is leaking so needs to do the pressure test to find it out.
IF i want to repair it or if needed to replace it how much it cost to me..
Jan 24, 2010 at 9:12 AM
DAVE H
  • 13,383 POSTS
to replace hose ? around £30 .. i would check for headgasket failure on this model
Jan 24, 2010 at 9:18 PM
DHUPS.GOSWAMI
[quote:9257c1e4d6="Dave H"]to replace hose ? around £30 .. i would check for headgasket failure on this model[/quote:9257c1e4d6]
So its not a big problem... The thing is i m thing to purchase this car rover 75 automatic 1999 ...
And the car had the problem .. so i asked here to help.. I m guessing that its not a big problem.. n it doesnt cost to much to repair ...?
THanks again..
Jan 25, 2010 at 1:52 PM
DAVE H
  • 13,383 POSTS
very easy and low cost repair .. if it is just the hose ... I would have a compression test of the cylinders carried out before buying as this model is well known for headgasket failure causing the symptoms your describing
Jan 25, 2010 at 8:04 PM
