v6 petrol automatic will not even turn over or start.
111,900 MILES
MICHAELMCMELLON
high I have arover 75 conoseur automatic v6 petrol car that in one day whent from intermitent sarting to not starting at all I have replaced the camshaft sensor, the crankshaft sensor , the ignition switch, and finally I a rechonditioned starter motor. but still it wont turn over.
when I turn the key the instuments light up I hear burring sounds as normal and a couple of clicking sound then when I turn key to start position nothing hapens at all. the verry last time I drove it the speedo failed.
Jul 3, 2013 at 5:28 PM
  • 110,248 POSTS
Do you mean the starter won't engage or it does and the engine won't start? Have you checked to see if there is power to the starter with the key in the start position? Have you checked the starter relay?
Jul 9, 2013 at 12:46 PM
