rough when it runs lacks power.
245,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
TRISHA2
  • 7 POSTS
when starting the ride need to push the gas when it running it runs rough shakes all over then losses power when at a complete stop it would slowly take off. when shut off engine and restarting it has power for a few miles then losses power again
Jan 9, 2014 at 11:26 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like you may have a few issues so you have to hold the gas pedal all the way to the floor to start it?
Jan 9, 2014 at 12:53 PM
TRISHA2
  • 7 POSTS
just a little press on the gas panels and later it would go on its own
Jan 9, 2014 at 1:39 PM
SATURNTECH9
  • 30,869 POSTS
So you for sure have a 2002 SL1?Because when you say you loose power and can barely take off and you cycle the key and power comes back for a while your describing going into reduced performance mode.Then cycling the key and temporary getting back out of reduce performance mode. The S model saturns dont have reduce performance mode because they dont have throttle by wire. Can you post a pic of the car?
Jan 10, 2014 at 12:10 AM
