Grinding in reverse car will not move
2004 PONTIAC SUNFIRE
150,000 MILES • 4 CYL • FWD • AUTOMATIC
CKAL
My car had been running great then one I parked my car after driving fine on the highway and I heard a noise that made me think the axles were going out. Then a little while later I tried to start it, it sounded fine until I put in reverse, it started grinding and and got so loud I thought it was going to explode so I turned it off. Two weeks later started it again sounded fine put it in reverse no grinding noise, but it would not move at all not even when given gas. I went to put it in park and it acted a little funny and the lights on the inside flickered a little, I was able to put in park and turned it off. What is going on with my car?
Feb 26, 2016 at 3:22 PM
CATAFINA
  • 167 POSTS
If it does not want to move in any gear it sounds like you will be needing another transmission.
Feb 26, 2016 at 4:32 PM
CAR-MAN145
  • 321 POSTS
I would have someone put it gear while you watch the axles to see if one turns when put in gear. If the car does not move it could have broken a axle. Be careful or take it to a mechanic. If you do the repair yourself make sure you use a rack. A broken axle is a lot less money than a transmission replacement. Good luck.
Feb 26, 2016 at 5:46 PM
CKAL
I know it is catching gear for reverse it is just not moving.
Feb 26, 2016 at 6:52 PM
CAR-MAN145
  • 321 POSTS
Yes, but is the axle moving?
Feb 27, 2016 at 6:15 AM
