Engine does not rev past 3,000 RPMs
200,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
STORMY_77
Won't rev past 3000 rpms.
Mar 29, 2022 at 10:52 AM
  • 110,248 POSTS
This could be the result of a few different things. The first thing I suggest is to check for diagnostic trouble codes. If you haven't done that yet, follow the directions below to see if codes are present. This vehicle has an OBD1 system, so you don't need a scanner to get codes.
https://www.2carpros.com/articles/nissan-obd1-diagnostic-trouble-codes-and-retrieval-procedure-1984-to-1994
Let me know what you find. Also, let me know exactly what happens when the engine reaches 3000 RPMs.
Mar 30, 2022 at 2:02 PM
