replacing rear axle bearings
200,412 MILES • 5.7L • V8 • 2WD • AUTOMATIC
ENVADER
You show how to do it, but is there two or just that one on the driver side?
Nov 8, 2019 at 2:52 AM
STEVE W.
  • 15,416 POSTS
There will be a bearing on each side. If you get yours apart and find that the axle is worn you can get a bearing that is offset so you don't need to buy new axles. The axle shaft is the inner bearing race on those so they can wear where the bearing rides.
Nov 8, 2019 at 3:42 AM
