2013 Ford Fusion Serpentine Belt Removal Fix
87,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • AUTOMATIC
STACEYR
I'm replacing my alternator I need a diagram of the serpentine belt so that I can get to the tension pulley to take belt off and replace alternator.
May 15, 2025 at 7:08 AM
STEVE W.
  • 15,419 POSTS
Here is the diagram. FYI to get the belt off you need to loosen the tensioner bolts. The catch to that is that the engine mount bolts to the tensioner, so you need to support the engine, then remove the mount for access. I have been able to coax the belt in between the tensioner pulley and the front case so you may want to try that first.
May 15, 2025 at 10:56 AM
Suggested Repair
Support the engine, remove the mount that bolts to the tensioner, then loosen the tensioner bolts to remove the serpentine belt. First try working the belt between the tensioner pulley and the front case.
Conversation Summary
The owner of a 2013 Ford Fusion asked for a serpentine belt diagram to reach the tensioner while replacing the alternator. The expert said the tensioner bolts must be loosened, the engine must be supported and the mount removed for access, and the belt can sometimes be worked between the tensioner pulley and the front case first.
