ECM replacement
9,100,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
DANIELLE DUVAL
  • 7 POSTS
Ground cable from battery (negative) broke off complete burned up four coil packs. do i need to replace the ECM? i don't know if there is damage to it or not. yet i am repairing all of this myself and don't know much yet? Nissan does not make any new computers for this year and model. so what do i do?
Feb 15, 2019 at 3:22 AM
Good afternoon,
Did you replace the battery cable with a new one? You need to do this first.
Burning the coils from a bad ground cable is common. They need to be replaced. Once they are replaced, I would see if it starts. You may or may not need to replace the ECM from a power spike.
Did anyone already tell you it needs to be replaced?
Feb 15, 2019 at 5:34 AM
DANIELLE DUVAL
  • 7 POSTS
No it is just what i read online. they said to replace the ground cable all six coil packs and the ECM. i have not done the work to it yet, i am still waiting on weather. i need to replace all of it or just the ground and coil packs?
Feb 15, 2019 at 5:38 AM
DANIELLE DUVAL
  • 7 POSTS
Okay, I will just replace the ground and coils and see what it does. i just didn't want to have to buy coil packs again because they said it will burn out again. also, Nissan doesn't make the ECM new anymore. what so i do about that if i have to get one where should i get one?
Feb 15, 2019 at 5:43 AM
There are plenty of places that still make the ECM. That's not an issue.
I would replace the cable and the coils first.
Feb 15, 2019 at 5:46 AM
DANIELLE DUVAL
  • 7 POSTS
Okay, thanks.
Feb 15, 2019 at 6:35 AM
You are welcome.
always glad to help.
Feb 15, 2019 at 6:38 AM
DANIELLE DUVAL
  • 7 POSTS
Hi Roy, I replaced the coil packs and the ground cable and the car won't start.
Feb 20, 2019 at 2:50 AM
DANIELLE DUVAL
  • 7 POSTS
Is there any way to test the ECM? I mean to do that how I know but not starting because Nissan wants me to tow it down there so they can do a diagnostic on it. which is another hundred fifty bucks plus $120.00 to have it towed. then they said that the new ECM is $784.00 and it's going to be $355.00 to reprogram it and labor. a lot of money.
Feb 20, 2019 at 2:54 AM
Okay, you would need an advanced scan tool that can read the ECM and it outputs.
So, now the ECM is available? The price is high. You could get a better deal at a private shop and save yourself a ton of money.
Feb 20, 2019 at 2:58 AM
