2005 Renault Scenic 6 cyl Front Wheel Drive Manual
rear heated window not working also external temperature readings are incorrect. Is this problem related to a fuse? Sorry I dont have a repair manual
Friday, February 13th, 2009 AT 5:12 PM
DAVE H
MECHANIC
The rear heated screen could be related to a fuse? Check the fuse box there should be a diagram on the lid for which fuse it is? The outside temp sensor is located near the radiator behind the front grill panel. It may need cleaning or replacing. Your local library should be able to lend you a manual. And there is a fuse diagram/location page in the vehicles handbook which came with the vehicle
