2004 Renault Scenic Rear passenger window opening itself
2004 RENAULT SCENIC
26,000 MILES • 4 CYL • 2WD • MANUAL
STUARTDALESA
i have a renault grand scenic, this morning a fault started where the rear window when being closed will on reaching the top rverse its action and reopen half way. i believe this is a known probelm on these cars. can some one help by telling me how to fault find this problem.
thanks,
Oct 13, 2008 at 9:34 PM
JIMMYTHEBRIT
  • 30 POSTS
it sounds like the anti-pinch system is cutting in and making the window go back down. this usually happens if there is some sort of blockage. check the runners up the window and give them a quick clean and clean the edge of the window glass too. if this doesnt rectify it then you may need to see a dealer.
Oct 18, 2008 at 9:26 AM
