1991 Renault 19 No Drive Engagement
RENAULT
ABAGO66
My 1991 renault 19 with engine 1.7L and with 107.000kms on the speedometer.with automatic transmission,is not engaging in to drive,it works for reverse and the car moves,but in drive the linkage is working fine but the car doesn't feel engaging and it won't move foward.the trans fluid level is ok.any help to where to start looking for it will be appreciate it.
Feb 11, 2007 at 7:39 PM
DAVE H
  • 13,383 POSTS
transmission may need a rebuild .. forward clutch's probably worn out. I would try a fluid and filter change by following this guide.
Is the speedometer working if not then the problem could be the vehicle speed sensor which is near the final drive axles of the transmission. Please let us know how to goes.
Mar 20, 2010 at 11:57 PM
Suggested Repair
Service the automatic transmission fluid and filter. Confirm the speedometer works; if not, inspect the vehicle speed sensor near the final-drive axles. If drive still will not engage, worn forward clutches may require a transmission rebuild.
Conversation Summary
The owner of a 1991 Renault 19 1.7L automatic says reverse works and the shift linkage moves, but drive does not engage and the car will not move forward. Fluid level is OK. The expert suggests a fluid and filter service, checking the speedometer and vehicle speed sensor if it does not work, and notes that worn forward clutches may require a transmission rebuild.
