1994 Other Renault Models timing belt marking
1994 RENAULT
200,000 MILES • 4 CYL • 2WD • MANUAL
DANY001
hi! i need to change the timing belt and i have the marking on the wheels on both, camshaft and crankshaft, but i cant find the marking on the engine block so i can line them up. can you help me please.
By the way, i did try to line up the crank shaft by putting the no 1 piston at the upper point using the sparkplug , but didnt work
Thank you
Dec 16, 2007 at 7:51 PM
DANY001
[quote:dcd14dfaf3="dany001"]Engine problem
1994 Other Renault Models 4 cyl Two Wheel Drive Manual 200000 miles
Thank you[/quote:dcd14dfaf3]
Dec 16, 2007 at 7:54 PM
