1999 Renault Megane ignition
CHRISFRANC
  • 1999 RENAULT MEGANE
Electrical problem
1999 Renault Megane 4 cyl Two Wheel Drive Manual
no spark from ignition coil, crank sensor working ok
no signal voltage to coil engine turning over but will not fire up, plenty of fuel. Whats the problem?
Sunday, June 21st, 2009 AT 10:06 AM
DAVE H
  • 13,384 POSTS
CKP (crank position) sensor sends a signal to the PCM (computer) PCM then sends a signal to the coil ... check the wiring from PCM to coil is not damaged and check you are getting a signal output from PCM !
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_797.png
Monday, June 22nd, 2009 AT 5:28 AM
