wipers do no work
TAM DEEPROSE
Four cylinder front wheel drive manual 98,000 miles
wipers do not work when switched on, but come on when you switch on the blower. However, the blower does not work.
Jan 5, 2008 at 2:27 AM
DAVE H
  • 13,383 POSTS
sounds like a bad wiring connection. you may need an auto electrician to track this down.
Mar 20, 2009 at 12:54 AM
ALISTAIR AUSTIN
tam,
sounds like you had exactly the same problem with your windscreen wipers as l am having with my Megane. did you manage to find the problem?if so could you let me know.
thanks.
Jan 3, 2011 at 1:51 PM
ALISTAIR AUSTIN
my windscreen wipers do not work when i use the switch. However, when i turn on my heater blower the wipers work at varying speeds according to how fast the heater blower is turned.The heater fan does not work.
Jan 11, 2017 at 8:57 AM (Merged)
DAVE H
  • 13,383 POSTS
have an auto electrician look at the vehicle you have a short on the wiring system.
