• HOME
  • ASK A QUESTION
  • REPAIR GUIDES
  • BECOME A MEMBER
  • LOG IN
    Login with Facebook
    OR
    NOT A MEMBER?FORGOT PASSWORD?
  • CONTACT US
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
  • Home
  • Nissan
  • Sentra
  • Engine
  • Starter
  • Relay
  • Replace/Remove
Relay starter replacement
  • PREV
  • 1
  • 2
  • NEXT
  • 31,937 POSTS
Hi there,
start at the starter, check main voltage and also solenoid voltage with key on crank, if 12V starter is faulty, no voltage at solenoid check relay next. Start here.
Mark (mhpautos)
Monday, December 28th, 2020 AT 1:19 PM (Merged)
  • PREV
  • 1
  • 2
  • NEXT
Related Starter Relay Replace/Remove Content
Removal Of Starter
How Do I Remove The Starter
Asked by allenhobdy ·
1998
NISSAN SENTRA
1993 Nissan Sentra Starter/solenoid
Car Would Not Start, I Tightened Cable From Battery At The Solenoid, Car Started Several Times. After I Waited About An Hour I Tried To...
Asked by strangstrummer ·
1993
NISSAN SENTRA
1997 Nissan Sentra Where Is The Starter
Could U Tell Me Where The Starter Is Located On A 97 Sentra Gxe 1.6l? Will Donate After Satisfaction Of Results.
Asked by daniel82 ·
1 ANSWER
1997
NISSAN SENTRA
Poss Starter Proplem
1997 Nessan Sentra 177,000 1.4 L I Just Changed A Battery And Replace The Battery Termanals. When I Turned The Key I Get The All The...
Asked by glenn.meade ·
NISSAN SENTRA
Hi, When I Try To Start The Car, A Terrible Noise, Similar To A Fork Being In A Garbage Disposal, Eminates From The Area Of Where The...
Asked by kheimbuch ·
1993
NISSAN SENTRA
VIEW MORE
Starter Motor Replacement
Starter Replacement
Starter Replacement
Starter Replacement
Starter Replacement
  • Contact
  • Help
  • About
  • Privacy Policy
  • Terms & Conditions
© 1999 - 2025 2CarPros, Inc.
