Reduce Power Mode?
85,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
PCGUY2
I have a 2014 Ford Fusion SE with the 1.5L engine. My wife was driving it to the store, and on the way back, the dashboard displayed a warning: "Engine Coolant Over Temperature." Shortly after that, the car stopped accelerating, which I believe was due to Reduced Power Mode activating.
We had the car towed home. The next day, I replaced the coolant temperature sensor and started the car, but it still seems to be stuck in Reduced Power Mode. Any reason why the car is still in Reduced Power Mode.
Sep 6, 2025 at 2:16 PM
  • 55,710 POSTS
Yes, the car is in limp mode, can I ask if you could hear the cooling fan running while you were getting this warning? If not this will be the problem. Also is the system full of coolant? I would check it when the engine is cold. We need more information to help you. Please go over these guides to get us started.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
Please go over these guides and get back to us.
Sep 7, 2025 at 2:53 AM
PCGUY2
The engine is cold (the car has been sitting for three days). The system coolant is full. Immediately when I start the engine, I hear the cooling fans running, I get the message "Engine Coolant Overtemperature". I already replaced the Coolant temperature sensor.
Sep 8, 2025 at 2:27 AM
  • 55,710 POSTS
Okay, then we need to run the codes to see which ones are stored which will help us fix it. Lett me know what you find.
Sep 8, 2025 at 4:25 AM
