No engine does not run. No crank, no start, only dash lights?
118,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
HAL1958
  • 89 POSTS
When starting engine cold after a few minutes when coolant temp gauge is about one third the red coolant temperature light comes on and engine shuts down and fuse 54 blows. Then it has no crank and no start. Replace fuse 54 and blows again when turning key to on position. I replaced coolant temperature sensor and thermostat housing and still the same. Disconnected the battery for an hour then connect and it will start and shut down again with temperature light on. No codes on scanner.
Sep 17, 2023 at 3:07 AM
  • 55,694 POSTS
Yep, this happens when the radiator cooling fan has gone out. here are the wiring diagrams for the fan and fuse #54 so you can see how the system works and I have included how to change the fan assembly out. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Sep 18, 2023 at 5:48 AM
HAL1958
  • 89 POSTS
Is there a test i can do maybe with a multimeter on the fan to make sure the control module is bad before i buy a new one ?
Sep 18, 2023 at 10:38 PM
  • 55,694 POSTS
The fan has a simple power and ground connection which powers and grounds the motor, they vary the small ground wire to the module to control the fan speed. I would check the main ground and power and if okay replace the fan module/motor.
This guide can help and use the wiring diagrams above:
Please let us know how it goes.
Sep 20, 2023 at 10:35 AM
HAL1958
  • 89 POSTS
I checked the ground and power wire and it’s good to fan. I ordered the fan. In the meantime, I disconnected both battery leads and ran a wire from positive lead to ground for a few hours. I read that I may reset the ECM and all control modules. When I reconnected the battery i got no crank anything. I connected my launch 3001 reader, and it said ECM. It’s a basic reader. Did i erase the ECM program when I grounded the positive lead? Maybe it doesn’t know the key anymore? What happened here? What can i do?
Sep 21, 2023 at 1:13 AM
HAL1958
  • 89 POSTS
Also, I forgot to mention that when I turn the key the dash lights come on but then no crank no sound at all. I hope the ECM is still good.
Sep 21, 2023 at 4:12 AM
HAL1958
  • 89 POSTS
Also, i jumper wire 3 and 5 on starter relay with key on position and engine cranks but no start. With relay back in key turned engine has no crank no sound. My reader now shows po607 code, control module performance.
Sep 23, 2023 at 12:25 AM
HAL1958
  • 89 POSTS
I replaced the fan assembly and also the crankshaft position sensor. I still have no crank and no sound at all using key. I decided to jumper the fuel pump relay and starter relay with key in on position and it cranks but no start. I thought doing this would bypass the ECM and it should be starting. I’m not sure? After that I connected my 3001 reader, and it showed control module performance po 607 again but this time also camshaft sensors 1 and 2. I’m not sure if the sensors are bad or if the ECM is bad and not reading the sensors information? Can you read my previous replies to see what i did? What troubleshooting can i do next to get my car running again?
Sep 24, 2023 at 1:57 AM
  • 55,694 POSTS
It sounds like you popped a fuse, I would use this guide and check all fuses I have also included the fuse locations.
test the fuses with the system on. Check out the images (below). Please let us know what you find.
Sep 25, 2023 at 12:31 AM
HAL1958
  • 89 POSTS
Checked all fuses one at a time and all good. Did a volt and ohms check on relays in engine compartment and checked good for starter, air pump, seq asg pump, term 15r, term15. Also checked in trunk the relays for fuel pump, term 15, term 15r. Also, good. I don’t know where the pre fuses are . I think where the battery jump connection is with the red cover. Are there some pre fuses there to check ?
Sep 25, 2023 at 5:26 AM
  • 55,694 POSTS
With the key on do you have power at fuse #5 in the under-hood fuse panel and fuse #54 on the front sam control fuse panel? Here is the main power distribution. You may have popped the front SAM controller. Check out the images (below). Please let us know what happens.
Sep 26, 2023 at 4:22 AM
HAL1958
  • 89 POSTS
Fuse 5 is in the trunk and my car does not come with that fuse, it’s empty. I check the power to fuse 54 under hood with key in second position and no volts. Is there a pre fuse that protects the front SAM that i can check? Also, how can I remove the SAM to check the circuit board? It looks like the wiper motor arm is in the way. Also how do I check the ECM? I heard they have problems with capacitors that go bad, and car will be dead. These parts are expensive, so I want to make sure it’s bad before I replace them. I want to do all the necessary troubleshooting first.
Sep 27, 2023 at 2:49 AM
  • 55,694 POSTS
Hmm, it looks like the info is incorrect, fuse #5 is for the fan control module and fuse 6 should be 60 amp but by the image you provided the fuse is 20 amp? Is this a Euro car?
Sep 28, 2023 at 3:10 AM
HAL1958
  • 89 POSTS
No, it’s not a Euro car. It’s called the Grand Edition model because it was the last year for clk350. I’m not sure if it’s a little different than the base model. I removed the front SAM and checked the circuit board, and it looks like new. Wiring and fuses all look good also. Part # is 2095452801. Part # of the ECM is A2721531092. Are there some prefuses that go to the front SAM? How can I check to see if it’s the ECM or the front SAM causing my no crank no start no sound?
Sep 28, 2023 at 9:19 AM
HAL1958
  • 89 POSTS
This is the fuse chart that came with the car.
Sep 28, 2023 at 9:49 AM
  • 55,694 POSTS
Okay, it this point we should run the codes for the CAN which will tell us if the SAM or PCM is not working. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Please go over these guides and get back to us.
Sep 29, 2023 at 3:25 AM
HAL1958
  • 89 POSTS
These are the codes i got using Launch 919x reader. Let me know if there are more checks i can do with this scanner to find problems. I would like to try the least expensive repair first that may fix my problem. I’m enclosing pictures of the screen codes.
Oct 7, 2023 at 11:34 PM
  • 55,694 POSTS
You got some codes there :) The majority of them seem to point towards the bad engine control module. But I did see a code for the circuit 87 which feeds the controller. Does the engine run? If so, I would clear the codes and then turn the key on without starting the engine to see if any come up. Also, can you remove the front SAM control wiring connectors to see if there is any corrosion? Also, you might be able to open the unit up to see if it smells burnt.
Oct 9, 2023 at 1:45 AM
HAL1958
  • 89 POSTS
No engine does not run. No crank, no start, only dash lights. With the key in start position no fuel pump sound or no starter clicking. The radiator fan still comes on high speed with key on and shuts off with key in off position. Replacing fan, I think was a waste of money. I checked the front SAM connector pins each one and circuit board and no corrosion. I opened ECM and board has no corrosion. I cleared all codes and then rescanned. I enclosed the pictures of codes. The ECM doesn’t show up in scan this time. When I tried to enter ECM in control units it showed communication error. Are there some checks i can do to see if ECM is sending signals to start car?
Oct 10, 2023 at 5:40 AM
  • 55,694 POSTS
I don't see the images? also testing the ECM can be difficult I would remove it and send it in for evaluation. Here are the starter wiring diagrams so you can see how the system works.
Oct 11, 2023 at 12:37 AM
HAL1958
  • 89 POSTS
Last scan pictures after clearing all codes and key in 2nd position. Is there anything i can do with my scanner to get the ECM to reset so the scanner can communicate with it?
Oct 11, 2023 at 5:47 AM
HAL1958
  • 89 POSTS
Can you send me a diagram of the ignition switch to all the components involved in starting the car including the PCM signal? Also, do you have a troubleshooting chart from Mercedes that shows step by step what to check in a no crank no start to pinpoint the bad component?
Oct 11, 2023 at 11:04 PM
  • 55,694 POSTS
Sure, here is the information you have requested. It still seems like the front SAM module to me. Check out the images (below). Please let us know what happens.
Oct 12, 2023 at 4:01 AM
HAL1958
  • 89 POSTS
I ordered a used front SAM with same part number from a 2007 clk350 to avoid programming. I’m hoping it will be plug n play. Will take a few days to arrive. The wiring diagram you sent me I don’t see the wires from the ignition switch to the other components. I would like to see where the signal goes in the wiring in all three key positions. So, i can check voltage at components. Can you send me that?
Oct 13, 2023 at 5:38 AM
  • 55,694 POSTS
yep, the ignition switch is the EIS control unit which I have provided above. Let me know what happens with the used front SAM module.
Oct 14, 2023 at 3:28 AM
HAL1958
  • 89 POSTS
I installed the used front SAM and it started right up. It ran for 10 minutes, and RPMs stayed high at about 1,200 and didn’t come down. The radiator fan came on when reaching operating temperature. I turned engine off and connected scanner. It has a lot of codes. Not sure if they came with SAM. I didn’t clear any. I wanted to see what you say after reviewing them. I’m enclosing them here.
Oct 17, 2023 at 12:26 AM
  • 55,694 POSTS
Yep, this could be because you stalled the SAM, I would clear them out and then turn the system on without starting the engine and then run the codes again, it does sound like we are getting closer to having the problem fixed.
Oct 17, 2023 at 2:45 AM
HAL1958
  • 89 POSTS
I cleared the codes then rechecked with the key on. I have a lot of codes still. TCM, ESM, ESP, SRS, IC, AGW. Front and rear SAM shows good. SRS is showing on dash not operating. Also, radio shows on screen diagnosis and will not turn on. I’m enclosing codes.
Oct 18, 2023 at 3:13 AM
HAL1958
  • 89 POSTS
Also, the ESP module in the engine bay is buzzing and ticking with key out. My battery is dead because of that using power. How can i fix that so it’s not running ? Is there a fuse i can pull in the meantime so it won’t kill my battery ? There is a lot of fuses for ESP so don’t know which one.
Oct 19, 2023 at 9:23 AM
HAL1958
  • 89 POSTS
2 more codes plus 3 above.
Oct 19, 2023 at 9:27 AM
  • 110,248 POSTS
I noticed it has been a couple of days since we made contact with you. Have you been able to make any progress? I'm interested in knowing.
Oct 21, 2023 at 1:49 PM
HAL1958
  • 89 POSTS
Did you have a chance to look at the codes above after replacing the sam ? I did not program the used sam just R & R. Not sure if i can use my launch 919x scanner to transfer program ? I have not tried to drive car with all those codes even though now it starts. The ESP is still buzzing and ticking using up my battery power. So I disconnected the battery for now. What is causing that ? What fuse can I remove in the meantime until it’s fixed ? Also radio is showing diagnosis on screen and will not come on. The SRS is showing inoperative on dash. What can i do next?
Oct 22, 2023 at 3:07 AM
HAL1958
  • 89 POSTS
I haven’t received a reply to my problem in more than a week. I may have to start a new post.
Oct 24, 2023 at 9:26 PM
HAL1958
  • 89 POSTS
I started the car today to do some checks. When the car reached normal temperature, the fan did not come on like before. It shut down and red coolant warning came on even though it was not overheating. I tried to restart, and it popped fuse #54 which was my problem before I replaced SAM. I replaced fuse and it started but shut down in a few seconds with coolant overheating light on. The A/C is off, so I don’t think it’s the A/C temperature pressure sensor. Should I try to disconnect the fan connector and A/C temperature sensor and start the car that way to see if it shuts down? Maybe it could be the PCM? I still need help to solve this.
Oct 25, 2023 at 1:02 AM
  • 55,694 POSTS
Sorry for the delay, yes, I looked at the codes and it does seem like the PCM is out. Here is the location so you can send it out to be checked. Check out the images (below). Please let us know what happens.
Oct 25, 2023 at 1:43 AM
HAL1958
  • 89 POSTS
Can you recommend a place to send out the PCM?
Oct 25, 2023 at 2:40 AM
  • 55,694 POSTS
I use AER in Fullerton, California.
Oct 26, 2023 at 4:24 AM
HAL1958
  • 89 POSTS
I called AER and they said they don’t work on Mercedes modules. Do you have another option?
Oct 26, 2023 at 6:44 AM
  • 55,694 POSTS
Not off hand, I would do a Google search to see who could test it for you.
Oct 27, 2023 at 1:15 AM
HAL1958
  • 89 POSTS
I sent out the PCM for testing and repair. I’ll let you know in a couple of weeks when I get it back if it fixes the problem.
Oct 30, 2023 at 9:31 PM
  • 55,694 POSTS
Sounds good, have a good week.
Oct 31, 2023 at 2:48 AM
