2002 GMC Yukon Mode Door Out of Range Fix
Disconnecting the negative post of the battery will make sure all power is disconnected from the module without pulling fuses.
The HVAC control module will relearn the actuator limits whenever power is disconnected and re-connected to the module.
Use the following steps to perform the calibration update:
1. Turn off the ignition.
2. Remove the battery positive voltage circuit fuse of the HVAC Control Module.
IMPORTANT:
- The scan tool must be disconnected from the vehicle to properly perform the calibration procedure. If a scan tool is connected before this procedure is completed, then new calibration values will not be stored.
- Failure to wait 60 seconds will not allow the HVAC control module sufficient time to clear the old calibration values.
3. Wait 60 seconds.
4. Install the fuse.
5. Turn on the ignition.
6. Wait 60 seconds before installing a scan tool.
First off, which type of HVAC are we working on? Manual or Auto and does it have dual zone or not?
Secondly, could you please describe the concern you are having: no temperature change at all, noises, etc.
I really want to help get this figured out. Thanks in advance.
First, let's make sure we have a good 5.0v reference voltage at the actuator. I marked that circuit in red on the schematic and pinout. With the actuator connector unplugged, turn the ignition on. Then check voltage between pin 10 and ground. You should get about 5.0 volts.
Second, test the ground circuit, marked in purple. From pin 7 to ground, the resistance should be less than 10 ohms.
If both of those circuits test good, let's make sure the position signal circuit is ok. You will need to disconnect the plug from the HVAC module for this one. Test resistance from pin 9 of the actuator connector to pin C4 (marked in yellow) of the HVAC connector. A good reading will be less than 10 ohms.
If all the circuit tests prove to be good, I would remove the blend air motor and then try to operate the blend air door manually. Make sure it moves freely through the full range. Please let me know how it goes.
I will be back home tomorrow evening, and I could get access to more information as needed. Thanks, and I apologize again for my confusion.
https://youtu.be/_jTN0X2TYvU
So, I think you fixed it, unless you want to replace the mode doors or the entire HVAC assembly. Let me know what you think.
Suggested Repair
Confirm the installed part is the mode-door actuator, not the similar temperature actuator, and verify the 5-volt reference, ground, and position-signal circuits. If those tests pass and the door still travels past its range, the mode door or HVAC case stop is likely worn. A mechanical stop can restore operation temporarily; the lasting repair is to replace the mode door or the HVAC assembly.
Conversation Summary
The owner of a 2002 GMC Yukon with automatic, single-zone HVAC asked how to recalibrate a replaced blend-door actuator after online procedures failed. The expert gave a battery/fuse power-loss recalibration, but the door still would not operate on its own even though a scan tool could command it and no codes were set. After clarifying that the concern was the mode door going out of range, the expert recommended checking reference voltage, ground, and the position-signal circuit, then manually checking door travel. The circuits tested good. The expert also noted that mode and temperature actuators have different part numbers and look similar. The owner added a small mechanical stop so the door could not travel past its limit, which restored operation. The expert agreed that this addressed the symptom and said a permanent repair would be replacing the mode doors or the HVAC assembly.
