Rear wheel bearings
93,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CRAIG MICHAELS
I watched your video on changing rear wheel bearings on a 2011 Silverado I have a 2011 Suburban which I was told is the same rear end, but I did not see you change the right side. the video showing how to do everything to the left now is there another C clip holding in the right side axle or is onr C clip holding both sides in?
Oct 13, 2016 at 12:47 AM
SATURNTECH9
  • 30,869 POSTS
There is one c clip for each axle.
Oct 13, 2016 at 1:16 AM
CRAIG MICHAELS
Okay, is there a trick to getting this c clamp out? I been playing with it for forty minutes and it just keeps spinning on me. do I have to have a magnet to pull it out?
Oct 13, 2016 at 3:34 AM
  • 55,649 POSTS
Try using a plastic mallet on the end of axle to push it in further and make sure its in all the way. Then use a magnet or try to trap it using two screwdrivers. Keep with it.
Please let us know what you find so it will help others.
Best, Ken
Oct 13, 2016 at 7:41 AM
CRAIG MICHAELS
Ok, thanks guys.. got it finished... all I needed was a second person to push the axle in a little harder while I was under the truck...thanks for your responses.
Oct 13, 2016 at 8:39 AM
  • 55,649 POSTS
Glad we could get it fixed please use 2CarPros anytime we are here to help.
Best, Ken
Oct 13, 2016 at 9:28 AM
