Rear wheel bearing goes out after changing
200,000 MILES • 4.6L
MICHAELG85
Replaced my rear driver side wheel bearing. I inspected the axle and housing for any damage but saw none. Once I took it on a test drive the new bearing failed within five miles. Not sure why it has failed.
Replaced the passengers side also and it is just fine.
Aug 5, 2019 at 1:14 PM
Good evening,
Do you have the bearing that presses into the housing or is it pressed on the axle?
What do you mean by failed?
Aug 6, 2019 at 8:38 AM
MICHAELG85
It presses onto the housing, and failed meaning completely destroyed. Bearings where all laying inside the housing and the metal was broken into at least 3 parts.
Aug 7, 2019 at 9:14 AM
Check for a bent axle. There is too much stress on the bearing.
Aug 7, 2019 at 10:59 AM
