Sounds like we need a recall !!! lol
I hate that everyone is having this same aggravating noise that I am but its also nice to know that I am not crazy and just hearing things or that I am the only one with this problem .. It sounds like a problem alot of folks are having so it would be nice if FORD looked into this. (Dont know if that is a possibility or not) But I forgot to mention in my post that I work with a guy that has an 01 and he is starting to have the same problem. Also I forgot to add that it was mentioned to me that maybe it was the dust shields rubbing ????? Hard to tell but here is my previous post as well ...... THANKS IN ADVANCE IF YOU CAN HELP !!!
Ive got the same problem and thats why I am here ... lol
I was hoping to run across a thread of this nature. I have a 2002 Fx4 F140 5.4 V8 with approx 63,000 miles on it and I am having the same noise from what appears to be the front drivers side. It may possibly be throwing the sound from somewhere else on the truck but when it is on a rack you cannot hear the noise its almost like the weight of the truck has to be on the tires. It started off that we knocker all the dirt and rust from the rotors. Still didnt help. Next we changed the pads on the truck , there was a lil less than half pad left but we changed them anyway. We replaced them with lifetime pads still no luck, next was (well it is making a noise at a certain spot everytime the wheel rolled in a certain spot) so we changed out the rotars because I was told maybe the rotars where warped. Then came the sanding down of the rotars in spots were rust was built up. Then I was told that a mechanic had worked on a truck with that similar problem and the pads werent shifting correctly and they "grinded" some of the pad out. But I knew that wouldnt fix it because it was doing it before this new set of pads and the noise stays there when the brake is applied. Next came the almighty wheel bearing $320 for parts and labor but I got lucky and that was not the problem either because it still made the noise after the new bearing was put on so they took the new one off and put the old one back on and didnt charge me for anything but I would have gladly paid the 320 if it would have taken care of the aggravating noise. The "noise" originally started at around 45 miles per hour and slowed down with the speed of the truck almost like it is "catching" in one certain spot . Now it is also heard when driving at a slow speed and is extremely irritating . I have had it at 2 different shops and with no luck the noise is still there, I am gonna try and take it to a ford dealer once I get some extra cash but for now any advice would be greatly appreciated. I can only describe it as a whistly type rubbing or catching noise with the rotation of a tire . It sounds like the front drivers side but I have been told that noises like that can be "thrown" from another tire for example I do not have much knowledge at all about vehicles but im not totally ignorant to things either but this is mind boggling . I love my ford and I dont want to burn it but the noise makes me want to !!! lol PLEASE HELP !!!
