Rear Suspension Wobble
61,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
JOHNNYD5
Between 50 and 65 mph I can physically see the rear end moving back and forth through the rear view mirror. I am pretty sure it is not the tires. I am on the second set of tires with multiple balances and rotations and the wobble is still there. I was wondering if it maybe was a problem with the bushings in the arms or maybe a bent piece. I guess I am just looking for a place to start without throwing parts at it. Thank you for any help you can give.
Apr 15, 2017 at 1:52 AM
CARADIODOC
  • 34,414 POSTS
Why do you say it is not the tires? Worn bushings rarely cause wobbles. Instead, the place to start is by jacking up one corner of the car so one tire is off the ground, then watch the tire tread and wheel lip as they rotate. You can spin rear wheels by hand. Some broken tire belts are real easy to spot, but some can not be seen unless you know exactly what to look for.
If the belts seem to be okay, the next step is measuring "lateral run out" with a dial indicator. Harbor Freight Tools has an inexpensive dial indicator. Place the probe on the lip of the wheel when that one is jacked up off the ground. If necessary, remove the wheel weights so they don't catch on the probe. Spin the wheel slowly, by hand, and read the amount of run out on the gauge. It typically takes at least around 0.035" run out before you will feel it.
If you find excessive run out, a bent wheel is the first suspect. Remove the wheel, then measure the run out on the hub. If that has little or no run out, check for impacted corrosion stuck between the center of the wheel and the hub. This is especially common on cars with cast wheels.
If you have rear disc brakes, the lug nuts must be installed to hold the brake rotor tight, then measure run out on the rotor's contact area the center of the wheel mounts to. That's just outside the wheel studs. If you find even a little run out there, the best suspect is some debris is stuck between the back side of the rotor and the hub.
The better suspect is still a broken tire belt. One of the clues is the wobble is felt more at a narrow range of speeds. The range you listed is right where the wheel has a natural tendency to bounce. The first thing to look for when spinning the tire is what appears to be a lump or tumor on one side of the tread. If you see that, be careful to not run your hand over the tread as there are usually very sharp wires sticking out. Those are part of the steel belts coming apart.
In many cases, that tumor grows so slowly that they wear down from normal driving. The tread surface can appear to be perfectly smooth. The elusive clue to the broken belt is to watch the grooves, and not the tread surface that contacts the road. I don't know why, but that type of belt problem almost always shows up on the inner edge of the tire, not the outer edge. If you see one of the grooves has a high spot as you spin the tire, suspect a broken belt. The effect of the broken belt isn't obvious until there is weight on the tire. This will also show up on a "road force" wheel balancer. All tire and alignment shops have them, as do many independent repair shops.
Apr 15, 2017 at 12:18 PM
JOHNNYD5
Caradiodoc I appreciate the information, thank you. The reason though that I do not believe it is the tires is because the same problem persisted with a second set of tires and the wheels all at different corners. That was my first thought so I tried changing tires and locations, but I did not get as technical as you suggest. So, I wonder if the wheels could all be bad. They are not in the greatest shape but they have been cleaned at a tire shop a couple of times and by me once. I guess I was wondering if it might be something in the rear end because there are so many parts with bushings back there it would not surprise me if it was throwing something off.
Apr 15, 2017 at 10:42 PM
CARADIODOC
  • 34,414 POSTS
Worn bushings won't cause a wobble. The only thing they can do is allow a wobble to occur, but it has to be caused by something that is rotating.
Before you go too much further, I'd have the tires checked on a road-force balancer. That starts out by spinning the assembly very slowly, and watching for uneven loading forces. If you see no sideways wobble, including in the next step when it spins the wheel much faster, watch for a wobble in the lip of the wheel when you spin it on the car, by hand. There has to be something that is being overlooked, and when you find it, you're going to smack yourself on your forehead.
Apr 17, 2017 at 12:00 PM
