Rear main seal will not budge
190,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
KEEPTRUCKIN
I am working on my truck myself because I can't afford the mechanic fees to have the rear main seal replaced. It has a 2 part rear main seal, after removing the oil pump you remove the rear crankshaft bearing block which also houses the lower half of the rear main seal. I have read to remove the upper part by tapping it through with a hammer and punch but it is stuck solid. I even read to try loosening the other crank bearing bolts which I tried but its still stuck. Is it worth risking buying/trying an air hammer?(I don't have one but could get one pretty cheap at harbor freight). The last thing I need is to have to remove the motor to remove a mangled upper seal as it is still in good enough shape to not leak too bad. Any advice is appreciated, thanks!
Aug 17, 2019 at 5:34 AM
Good afternoon.
No, do not even consider the air hammer. You will damage the crankshaft.
Loosen all the main bearing caps so the crank drops down a little.
There is a tool called a Chinese finger that you use to remove and install the seal. It screws into the seal and pulls it around. Parts stores carry them. If you have a NAPA store, they have them.
Aug 17, 2019 at 6:03 AM
KEEPTRUCKIN
Okay, I will give it a shot. Just to be clear, the seal on this truck is a rubbery silicone substance molded onto a thick steel wire core, not the hose type of seal. Would that tool still work?
Aug 17, 2019 at 6:30 AM
Okay, no it will not.
You need to use a thin screwdriver to release both sides and try to get it to move.
It will take time and patience to remove it.
Aug 17, 2019 at 6:39 AM
KEEPTRUCKIN
Alrighty, thank you!
Aug 17, 2019 at 6:52 AM
You are welcome.
Always glad to help.
Aug 17, 2019 at 8:06 AM
