rear hatch won't open with key fob or button inside cabin, but will close w/key fob/cabin button
2007 CHRYSLER ASPEN
95,000 MILES • 5.7L • 4WD • AUTOMATIC
DMSCHELL
I have a 2007 Chrysler Aspen and I love it. However, for some reason, my hatch has stopped working properly. It will no longer open using the button on the key fob or the button inside, but it will close using the key fob and button inside. When I push either button the lights flash, but nothing happens. What could be wrong?
Jan 23, 2014 at 2:21 AM
CARADIODOC
  • 34,381 POSTS
This is another system the insane engineers have hung a computer onto, but the good news is that makes diagnosis somewhat easier. Your best bet with this is to visit the Chrysler dealer. Their scanner will provide more information than the aftermarket scanners used by independent shops, although some of them get pretty close. From working on one of these with a friend who specializes in rebuilding smashed Chrysler vehicles, I can share that if the gate pops open, then immediately closes again, the striker needs to be readjusted, and if the gate goes all the way up, then immediately comes back down, the range switch on the transmission is out-of-adjustment. Other than that, all of the inputs to the computer will be displayed on the scanner. Chrysler usually does a pretty good job of listing each item in a way that is easy to understand. For example, one item might be listed as "brake light switch circuit", not "B03 circuit". The computers can also store diagnostic fault codes. Those are especially helpful when you're looking for the cause of an intermittent problem.
Jan 23, 2014 at 10:00 PM
