Whining noise in the that gets louder as I accelerate
209,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
MICHELLE BRADLEY
  • 10 POSTS
How can I check the rear fluid. Have a whining noise that gets louder has I accelerate. Was told it was the hub assembly. Replaced that but noise is still there.
Jun 7, 2018 at 11:15 AM
HARRY P
  • 2,292 POSTS
There is no "rear fluid" or rear differential to check in that vehicle because it is a front wheel drive vehicle. Unless it is an all wheel drive. I will say that it could possibly be the other hub assembly. Does the noise change as you go around curves, or accelerate/decelerate? Normally, the faster you go, the louder (and potentially higher pitched) the noise will be.
Jun 7, 2018 at 12:46 PM
MICHELLE BRADLEY
  • 10 POSTS
Yes, when I accelerate it gets louder. I checked all the tires to see if there is play in any of them and there is not any play.
Jun 7, 2018 at 12:50 PM
HARRY P
  • 2,292 POSTS
You would not necessarily feel any play in the wheels. There would not be any noticeable play in the tires unless the hub was about to come apart.
Jun 7, 2018 at 12:57 PM
MICHELLE BRADLEY
  • 10 POSTS
Ugh. I was also told that the tires could make the same noise.
Jun 7, 2018 at 1:08 PM
MICHELLE BRADLEY
  • 10 POSTS
I just do not what to keep wasting money.
Jun 7, 2018 at 1:10 PM
HARRY P
  • 2,292 POSTS
To check and see if it is the tires, you can rotate them. Basically, you would be putting the rear wheels on the front, and the front ones on the rear. Then drive the car and see if the noise moved with the tires. If it moved, then it is the tire.
Jun 7, 2018 at 1:11 PM
MICHELLE BRADLEY
  • 10 POSTS
Thanks I did not even think about that. Duh it has been a day. Just been trying to figure out this noise.
Jun 7, 2018 at 1:12 PM
HARRY P
  • 2,292 POSTS
Well hopefully it will be something nice and simple like that.
Jun 7, 2018 at 1:14 PM
MICHELLE BRADLEY
  • 10 POSTS
Yeah me too. I already replaced one rear hub assembly this morning and it was not fun. So if it is the hub then I have to order it in the morning because they do not have any in stock. However, if it is the tires there is a lot more money.
Jun 7, 2018 at 1:17 PM
Good morning.
You can tell if it is the tires by having them rotated and see if the noise travels to the front. That would confirm a tire issue.
The hub bearings are common issues. Also, the rear fluid is an issue. It must be changed every 50,000 miles or the bearings in the rear will fail. They take special fluid for that change.
https://www.2carpros.com/articles/bearing-hub-replacement
https://www.2carpros.com/articles/wheel-removal-and-re-installation
Jun 7, 2018 at 2:19 PM
HARRY P
  • 2,292 POSTS
Hey Michelle, it has come to my attention that the 3.6L Rendezvous is an All Wheel Drive vehicle. So if you are sure that you have a 3.6L engine, then the rear fluid could be your issue. It uses a specific lube and has two oil pumps in it along with the gears. When the front end spins a bit the rear pumps rotate at different speeds and clamp the clutches on to power the rear axle. Whine can be from the pumps or internal pinion bearing or even the joint at the front of the torque tube. The unit bolts to the body with minimal isolation and noises become much louder. Lube is VersaTrak Fluid GM # 12378514
I will look into how to check the fluid if rotating the tires does not work.
Jun 7, 2018 at 8:44 PM
MICHELLE BRADLEY
  • 10 POSTS
Okay, I am going to rotate tires this morning.
Jun 7, 2018 at 9:42 PM
MICHELLE BRADLEY
  • 10 POSTS
It is fixed, yay.
Jun 8, 2018 at 9:09 AM
HARRY P
  • 2,292 POSTS
Well that is a little unexpected, but we will take it! Please let us know if there is anything else we can ever do for you.
Jun 8, 2018 at 12:10 PM
MICHELLE BRADLEY
  • 10 POSTS
Oh, I will and thank you for your help. I am just happy the noise is gone.
Jun 8, 2018 at 12:12 PM
  • 55,688 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Jun 11, 2018 at 5:41 AM
MICHELLE BRADLEY
  • 10 POSTS
Thanks and I will.
Jun 11, 2018 at 5:42 AM
