2002 Buick Rendezvous whining noise and vibration on accele
2002 BUICK RENDEZVOUS
124,000 MILES • 6 CYL • AWD • AUTOMATIC
JENNY1978LS
My truck has been making a whining type of sound from the rear end when turning for the last few months. I noticed it a few days after i bought it from a private party. It makes the noise when cranking the wheel all the way to turn in a parking spot and sometimes when a turn a corner sharp. The more i turn the wheel the louder it gets.My mechanic cant figure out what it is but thinks it has to do with the awd. He said it sounds like rubber rubbing together. I have also noticed a vibration noise that i think may be coming from the rear but im not sure. It makes the vibration when going from a stop and accelerating to about 40 then its stops once i get to 40. What is it? I was told its not unsafe and to wait and see what happens and leave it alone for now. I want to get rid of it if its something major.
Sep 18, 2009 at 12:49 PM
  • 110,244 POSTS
Check the tires for shifted belts for the vibration or rotate the tires to see if the vibration changes. AS far as the noise, does it only happen when the wheels are turned?
Dec 8, 2009 at 2:49 AM
