2002 Buick Rendezvous
KAIWALLACE2005
  • 2002 BUICK RENDEZVOUS
Noises problem
2002 Buick Rendezvous 6 cyl Two Wheel Drive Automatic
Good Morning,
My Rendevous makes a grinding noise when I make a sharp turn. It also vibrates (almost like it's rubbing against something). My guess would be that I need an alignment, but since I am not even close to being a mechanic, I was hoping that one could at least point me in the right direction. Thanks!
Friday, January 29th, 2010 AT 11:48 AM
  • 109,885 POSTS
IF you hear a grinding noise, I would recommend having the brakes checked first. Also, do you hear any grinding when you are driving straight? Finally, check the backing plate behind the front brake rotors to make sure they are not bent or rusted and touching the brake rotor.
Let me know what you find.
Thursday, March 11th, 2010 AT 9:47 AM
