2004 Buick Rendezvous barrings
2004 BUICK RENDEZVOUS
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
KRYSTISHELTON
My 2004 buik rendezvous has a problem I think. I have replaced the barrings twice now since I have owned it. It is at about 95 thousand miles now, and I baught it when it was at 30 thousand miles. It kind of makes a grinding sound when I stop sometimes. I have replaced the brake pads....even know they where not bad. It sounds like a boat after so long when you are driving on the highway. That is how I know the barrings are going out. So this will be the third time I will have to replace a barring since I have owned the vehicle. I know more then a average woman about fixing a vehicle. My dad taught me a lot as a kid. I know how to replace a lot of things without taking it to the shop. but this barring problem has not ever came up in my life. I guess my question is what could be causing my barrings to go out so frequentally?? I might be good with cars, but not that good. so PLEASE help me with some good advice. thank you and have a great day.
Nov 18, 2009 at 1:20 PM
  • 110,240 POSTS
Actually, this seems to be a somewhat common problem with these cars. I feel it is a design flaw, but can't prove it. Wheel bearings should last over 100K as far as I'm concerned. However, in most cases they don't on these models.
All I can recommend it to get a quality bearing to replace the bad ones. Try to purchase ones made in the USA and not the cheaper imported ones.
I will assume that when you make turns, the sound changes.
Dec 8, 2009 at 2:30 AM
