Does my differential have a limited slip
93,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
GLASSMAN009
  • 8 POSTS
I want to change the fluid and I need to know if mine has limited slip or not.
The housing is marked v648r051120712e.
Sep 8, 2018 at 4:25 AM
BMDOUBLE
  • 1,139 POSTS
The easiest way to find out is to jack up the rear end and spin one wheel by hand with it in neutral. If the other wheel rotates the opposite way then you do not have limited slip. Conversely, if it rotates the same way it is limited slip.
Sep 10, 2018 at 1:55 AM
GLASSMAN009
  • 8 POSTS
Can you tell me how to replace the plastic panel on my 2005 explorer, it is on the rear hatch below the glass it has the Ford emblem in the middle of it, thank you.
Sep 10, 2018 at 7:33 AM
RENEE L
  • 1,260 POSTS
Hello GLASSMAN009,
Thank you for using 2CarPros. Please post the question you are asking regarding replacing plastic panel on a new thread. You are asking about a different issue. In order for the site to properly index the question it needs to be a separate question. Please submit plastic panel question here: https://www.2carpros.com/questions/new
Make sure you are logged into the first.
Thank you and have a great rest of your day.
Renee
Admin
Sep 10, 2018 at 8:36 AM
