1999 Ford Explorer Rear Axle Fluid
TMFRENDA
  • 7 POSTS
1999 Ford Explorer XLS
How do I check the rear axle level? I see the pumpkin and checked everywhere for a drain plug is it on top if so how do I at home with floor jacks and stand check the fluid
Mar 30, 2006 at 5:14 AM
PEPPERMRJ
  • 1,158 POSTS
There iis a filler plug on the driveshaft side of the pumpkin. It is unique in that it is removed by inserting the square end of a ratchet extension (3/8th drive) into the plug. When removed gear oil should just tricke out with the car sitiing normally on the level. If not add the proper grade lubricant (see owners manual) until it does trickle out.
Good luck and let us know. :)
Mar 31, 2006 at 2:28 PM
TMFRENDA
  • 7 POSTS
thanks found it and I am pleased
Apr 3, 2006 at 12:48 AM
Suggested Repair
Check rear axle fluid at the filler plug on the driveshaft side of the differential. Remove the plug with the square end of a 3/8-inch drive ratchet extension. With the vehicle sitting level, gear oil should just trickle out; if it does not, add the grade specified in the owner's manual until it does.
Conversation Summary
The owner of a 1999 Ford Explorer XLS asked how to check rear axle fluid level and where the plug is, including whether it can be done at home. The expert said the filler plug is on the driveshaft side of the differential and is removed with a 3/8-inch ratchet extension. With the vehicle level, fluid should trickle out; if not, add the lubricant specified in the owner's manual until it does. The owner later confirmed they found the plug.
